Kind
Kind
Enum Indicates this Subcondition's behavior. Possible values for this property are the following:
0: Alarm (default)
1: Event
2: Return
If the Event property, common to all Alarm Sources, is set to True, this property cannot be modified, and its value always remains in 1 (one, Event). This property cannot be changed while this object is active.
