Enabled |
Defines whether Demo Tag variation is activated. If True, a Demo Tag updates its Value property according to the settings in the Period and the Scan properties. Otherwise, variation is disabled. Default value is True. Example:
Sub CommandButton1_Click()
Application.GetObject("Data.DemoTag1").Enabled = True
