BackStyle
BackStyle
Enum Specifies a background style for objects in a Report. The available options for this property are the following:
0 - ddBKTransparent: Transparent (default, displays the color defined by Section's BackColor property)
1 - ddBKNormal: Normal (displays the color defined by object's BackColor property)
NOTE
This property is not valid for Line, Barcode, Page Break, and Frame objects.
