TotalFailedWrites
TotalFailedWrites
Number Indicates the total amount of operations on .e3o files that failed and were discarded since the database connection was activated. This property can be automatically zeroed in several situations, such as:
When deactivating the DBServer object
If the E3DBEngine process is closed for any reason
If configuration parameters of the DBServer object's connection were changed
