nRetries
nRetries
Number This property specifies the number of times E3 tries to perform a database operation, in addition to the first one. The default value of this property is 5 (five). If the value of this property is equal to 0 (zero), only one try is performed by operation. In case there is a database connection loss during any of these tries, that operation is aborted and the remaining attempts are dismissed.
