Style
Style
Enum Determines a style for a Barcode. The available options for this property are described on the next table.
Available options for the Style property
Option
Description
0 - ddbcNone
Default bar code style
1 - ddbcAnsi39
ANSI 3 of 9 (Code 39) bar code style. Uses letters, numbers, -,*, $, /, +, %, etc.
2 - ddbcAnsi39x
Extended ANSI 3 of 9 (Extended Code 39) bar code style. Uses full ASCII characters
3 - ddbcCode_2_of_5
2 of 5 bar code style. Uses only numbers
4 - ddbcCode25intlv
Interleaved 2 of 5 bar code style. Uses only numbers
5 - ddbcCode25mat
Matrix 25 bar code style
6 - ddbcCode39
Code 39 bar code style. Uses letters, numbers, -, *, $, /, +, %, etc.
7 - ddbcCode39x
Extended Code 39 bar code style. Uses full ASCII characters
8 - ddbcCode_128_a
Code 128 A bar code style. Uses numbers, punctuation, or letters
9 - ddbcCode_128_b
Code 128 B bar code style. Uses Strings, numbers, punctuation, or letters
10 - ddbcCode_128_c
Code 128 C bar code style. Uses only numbers
11 - ddbcCode_128auto
Code 128 Automatic bar code style. Uses full ASCII characters. Automatically selects codes between 128 A, B, and C to configure the smallest value in the bar code
12 - ddbcCode_93
Code 93 bar code style. Uses letters, numbers, -, *, $, /, +, %, etc.
13 - ddbcCode_93x
Extended Code 93 bar code style. Uses full ASCII characters
14 - ddbcMSI
MSI Code bar code style. Uses only numbers
15 - ddbcPostNet
PostNet bar code style. Uses only numbers and a check digit
16 - ddbcCodabar
Codabar bar code style. Uses A, B, C, D, +, -, :, /, or numbers
17 - ddbcEAN_8
EAN-8 bar code style. Uses only numbers (seven numbers and a check digit)
18 - ddbcEAN_13
EAN-13 bar code style. Uses only numbers (12 numbers and a check digit)
19 - ddbcUPC_A
UPC-A bar code style. Uses only numbers (11 numbers and a check digit)
20 - ddbcUPC_EO
UPC-E1 bar code style. Uses only numbers. Used for UPC zero-compression symbols. In the Caption property, users can enter six digits of a UPC-E code or 11 digits. If an 11-digit code is inserted, then this bar code converts it to six UPC-E digits, if possible. Otherwise, converts from 11 to six UPC-E digits and nothing is displayed
21 - ddbcUPC_E1
UPC-E1 bar code style. Uses only numbers. The width of input data of UPC E1 is six number characters
22 - ddbcRM4SCC
Royal Mail RM4SCC bar code style. Uses only letters and numbers and a check digit. This bar code is used in Great Britain
23 - ddbcUCCEAN128
UCC/EAN_128 bar code style. Uses full ASCII characters. This special version of Code 128 is used on HIBC applications
