CaptionPosition
CaptionPosition
Enum Specifies the position of the text in the Caption property of a Barcode object. The available options for this property are the following:
0 - ddbcCaptionNone: Text of the Caption property does not appear in the Barcode (default)
1 - ddbcCaptionAbove: Text of the Caption property appears above the Barcode
2 - ddbcCaptionBelow: Text of the Caption property appears below the Barcode
