SrcLoValue
SrcLoValue
Number This property specifies the lowest value reached by the source. Example:
Sub SrcLoValue_ValueChange()
  On Error Resume Next
  Dim Bind
  Set Bind = Screen.Item("ScrollBar1").Links.Item("Value")
  Screen.Item("ScrollBar2").Min = Value
  If Bind Is Nothing Then
    MsgBox "ScrollBar1 has no link."
  Else
    MsgBox "ScrollBar1 is linked to " & Bind.Source & "'"
    MsgBox "Changing SrcLoValue from " &_
      Bind.SrcLoValue & " to " & Value
    Bind.SrcLoValue = Value
  End If
NOTE
In case the values specified for SrcHiValue and SrcLoValue properties are the same, there is no scale, then this Link works as a Simple Link.
