Format
Format
Text The Format property specifies the type of format applied to this object. It allows changing the way data is displayed without changing data behind it. This property can be manually edited or configured using the formatting window. Its usage is similar to formats used on spreadsheets, following the same basic syntax. Data types described on the next table are supported.
Data types supported by the Format property
DATA
DESCRIPTION
Numerical
Decimal, scientific, hexadecimal, binary, and octal output
Text
General text
Boolean
Boolean values
Date and Time
Gregorian calendar
