Properties
Properties
This section contains information about the properties of an Axis object.
NOTE
The AutoAxis, HorAxis e VerAxis properties are properties from the Collection of Axes that access default Automatic, Horizontal, and Vertical Axes, respectively. For example, instead of using "Chart.Axes.Item('HorizontalAxis')", users can use "Chart.Axes.HorAxis". All other user-created Axes must be accessed by their names using the Item method.
The available properties on this section are the following:
Color
EnableScaleColor
EnableTextColor
Format
GridColor
GridStyle
Inverse
MinorTicks
Mirror
Name
NormalBandColor
NormalBandHighValue
NormalBandLowValue
NormalBandVisible
Position
ReferenceLineColor
ReferenceLineStyle
ReferenceLineValue
ReferenceLineVisible
ReferenceLineWidth
ScaleType
ShowGrid
Title
UsePenEUAsTitle
Visible
