OnRead |
OnRead()
Occurs when an OPC UA Tag's value is received from an OPC UA server. Use the OnRead event to perform some operation right after a data is modified in the OPC UA Tag object (the Bit00 to Bit31, Quality, RawValue, TimeStamp, or Value properties).
