MouseDown
MouseDown
MouseDown(Button, ShiftState, MouseX, MouseY)
This event occurs when any mouse button is pressed on a Screen. Use the MouseDown event to determine specific actions when a user clicks a Screen.
Parameters of the MouseDown event
Name
Description
Button
Displays the pressed mouse button:
1: Mouse left button pressed
2: Mouse right button pressed
4: Mouse middle button pressed
ShiftState
Displays the pressed key along with the mouse button:
4: SHIFT key
8: CTRL key
12: CTRL + SHIFT keys
MouseX
Displays Screen's X coordinate where the mouse pointer was clicked
MouseY
Displays Screen's Y coordinate where the mouse pointer was clicked
Example:
Sub InitialScreen_MouseDown(Button, ShiftState, MouseX, MouseY)
  ' Quits the application when a mouse click occurs
  ' on the InitialScreen object.
  Application.Exit()
