KeyUp
KeyUp
KeyUp(KeyCode, Shift)
This event occurs when a key is released, regardless of the Screen focus.
Parameters of the KeyUp event
Name
Description
KeyCode
Integer identifying the ASCII character of the pressed key
Shift
Displays the shortcut key used with the pressed key:
4: SHIFT key
8: CTRL key
12: CTRL + SHIFT keys
Example:
Sub Screen1_KeyUp(KeyCode, Shift)
  ' Displays a message box when a user
  ' releases a key
  MsgBox "Key code: " & KeyCode
NOTE
For a list with all key codes available for the KeyCode parameter, please check the article Keys Enumeration on Microsoft Developer Network.
