KeyDown
KeyDown
KeyDown(KeyCode, Shift)
This event occurs when a key is pressed, regardless of Screen focus.
Parameters of the KeyDown event
Name
Description
KeyCode
Integer identifying the ASCII character of the pressed key
Shift
Displays the shortcut key used with the pressed key:
4: SHIFT key
8: CTRL key
12: CTRL + SHIFT keys
Example:
Sub Screen1_KeyDown(KeyCode, Shift)
  ' Displays a message box when
  ' a user presses a key
  MsgBox "Key code: " & KeyCode
NOTE
For a list with all key codes available for the KeyCode parameter, please check the article Keys Enumeration on Microsoft Developer Network.
