OnTagWrite |
OnTagWrite(Tag, Succeeded, User)
Occurs when a writing operation is triggered on any Driver Tag.
OnTagWrite event variables
Name |
Description |
Tag |
A reference to the Tag object being written. For example, users can access the Tag property using a syntax such as Tag.DocString |
Succeeded |
A Boolean value indicating whether a writing operation was successful or not |
User |
Parameter that receives the name of the user performing the writing operation. Default value of this parameter is "System". If there is no user logged in the E3 Viewer generating this event, this parameter contains the value "Anonymous" |
