OnAsyncQueryFinish
OnAsyncQueryFinish
OnAsyncQueryFinish(Recordset, Error)
Occurs when the GetAsyncADORecordset method returns. The Recordset parameter is an ADO Recordset object generated by the Query and the Error parameter is a Boolean that, when True, indicates that the object could not be generated. Example:
Sub query1_OnAsyncQueryFinish(Recordset, Error)
  MsgBox "Returned " + CStr(Recordset.RecordCount) + " records"
