VerticalFillStyle
VerticalFillStyle
Enum Defines an object's vertical fill. This property works along with the VerticalPercentFill property, which informs the percentage of an object to fill. These two properties allow a simulation of a level fill on an object.
Available options for the VerticalFillStyle property
Option
Description
0 - FillBottomToTop
Fill percentage is from bottom to top (default)
1 - FillTopToBottom
Fill percentage is from top to bottom
2 - FillCenterToEdgesV
Fill percentage is from center to border
