MouseIcon
MouseIcon
Picture This property sets an image to the mouse pointer whenever it moves over an object. This property is valid only when the MousePointer property is defined as 99 - fmMousePointerCustom.
An image file can be selected to use as a mouse pointer in two different ways: using the Properties List (.cur or .ico extensions) or via scripts, by using the LoadPicture method to specify a file path and name containing a customized icon (.cur extension only). Example:
Sub CommandButton1_Click()
  ' Setting the 99 - fmMousePointerCustom item to this property
  ' so that it accepts mouse icon customization
  Screen.Item("CheckBox1").MousePointer = 99
  Screen.Item("CheckBox1").MouseIcon = LoadPicture("c:\a.cur")
