KeyDown
KeyDown
KeyDown(KeyCode, Shift)
This event occurs when a key is pressed and an object has the keyboard focus. Notice that this event is not generated if an object is not enabled (its Enabled property is set to False) or if this object does not have keyboard focus.
Variables of the KeyDown event
Name
Description
KeyCode
Integer identifying the ASCII character of the pressed key
Shift
Displays the shortcut key used with the pressed key:
4: SHIFT key
8: CTRL key
12: CTRL + SHIFT keys
NOTE
For a list with all key codes available for the KeyCode parameter, please check the article Keys Enumeration on Microsoft Developer Network.
