FillStyle
FillStyle
Enum This property specifies a fill style for Screen objects. The next table contains valid values for this property.
Available options for the FillStyle property
Option
Description
0 - Solid
Fill style is solid (default)
1 - Hollow
There is no fill style
2 - Horizontal
Fill style contains horizontal stripes
3 - Vertical
Fill style contains vertical stripes
4 - Downward
Fill style contains stripes from down left to right in a 45-degree angle
5 - Upward
Fill style contains stripes from up left to right in a 45-degree angle
6 - Cross
Fill style contains horizontal and vertical stripes
7 - DiagonalCross
Fill style contains stripes up and down from left to right in a 45-degree angle
8 - Gradient
Fill style contains a gradient using both the ForegroundColor and the BackgroundColor property. This effect is determined by the GradientStyle property
9 - SemiTransparent
The Screen object remains semitransparent
10 - MouseArea
There is no fill style, but the Screen object remains responsive to events
11 - Background
Fills the Screen object with the color defined in the BackgroundColor property
NOTE
This property is not available for Picture, Dynamic Move, and Dynamic Rotate objects.
