Analog Alarm Source
Analog Alarm Source
This section contains information about the properties of an Analog Alarm Source (AnalogLevelAlarm) object. This object does not contain events nor methods associated to it.
NOTE
When the value of the Event property, common to all Alarm Sources, is set to True, the HiEvent, HiHiEvent, LoEvent, and LoLoEvent properties cannot be modified, that is, all alarm sub-conditions behave as events.
