Zones
Zones
Defines a set of Zones (TextZone) for an E2Text object. These Zones can be configured by accessing object's Properties window, on its Zones tab. Available options for this tab are described on the next table.
Available options for Zones tab
Option
Description
Zones
List with all Zones defined for this object
Add
Adds a new Zone
Remove
Removes the selected Zone
Blinks every (ms)
Defines whether text and background of a Zone blink when this object's value is inside a Zone's interval
Message
Text of a message displayed when this object's value is inside a Zone's interval
Alignment
Defines a text alignment
Font
Defines a text font
Background Color
Defines a color for Zone's background
Transparent
Defines if this object's background is transparent when this Zone is active
Default zone
Defines the selected Zone as object's default Zone
Blink
Defines if this Zone blinks when this object's value is inside a Zone's interval
Minimum
Minimum value for this Zone
Maximum
Maximum value for this Zone
Tip
Displays a help text for this Zone
Example
Displays an example of this Zone's behavior at run time
