Zones
Zones
Defines a set of bitmap images used to create an animation effect on this object. Zone (AnimationZone) objects can be configured by accessing object's Properties window, on its E2Animation tab. The available options for this tab are described on the next table.
Available options for E2Animation tab
Option
Description
Zones
List with all Zones defined on this object
Add
Adds a new Zone
Remove
Deletes the selected Zone
Default zone
Defines the selected Zone as object's default Zone
Blink
Defines if a bitmap blinks when this object's value is inside this Zone's interval
Tip
Displays a help text about this Zone
Minimum
Minimum value for this Zone's variation
Maximum
Maximum value for this Zone's variation
Image file
Name of a bitmap file that is displayed when this object's value is inside this Zone's interval
Example
Displays a preview of a bitmap file of the selected Zone
