Common Properties
Common Properties
This section contains information about the common properties of E2Control objects. The available properties on this section are the following:
Frame_BorderColor
Frame_BorderEnabled
Frame_BorderThickness
Frame_Color
Frame_Enable
Frame_Enable3D
Frame_Separator
Frame_Set3DInset
Frame_Thickness3D
Frame_Title
Frame_TitleColor
Frame_TitleEnabled
Frame_TitleFont
