VerGrid
VerGrid
Enum Determines a type of line to apply on E3Chart's vertical grid. The available options are described on the next table.
Available options for VerGrid
Option
Description
0 - Solid
Applies a solid line on E3Chart's vertical grid
1 - Dash
Applies a dashed line on E3Chart's vertical grid
2 - Dot
Applies a dotted line on E3Chart's vertical grid (default)
3 - Dashdot
Applies a dash-dot line on E3Chart's vertical grid
4 - Dashdotdot
Applies a dash-dot-dot line on E3Chart's vertical grid
5 - Invisible
Applies an invisible line on E3Chart's vertical grid
