ColumnTextAlignment
ColumnTextAlignment
Enum Determines the text alignment of E3Browser's columns. Possible values for this property are 0: taAlignLeft (default), 1: taAlignCenter, or 2: taAlignRight. When selecting a value for this property, all values with the same alignment on the Text Alignment column of the list of fields on the Query tab of E3Browser's Properties Window are changed to that selected value.
