Define an Interval Between REC's Statistical Log
This options allows configuring the frequency, in seconds, of REC protocol statistics' log recording. Default value of this option is 300 (five minutes). A value of 0 (zero) disables periodic log generation, and the minimum accepted value is 10. In case of typing a value between one and nine in this field, E3 then uses 10 s.
Interval between REC's statistical log (seconds) option
