Define a Number of Retries in Case of Ping Failure
Defines the number of retries in case of failure of a ping command. Default value of this option is 0 (zero, no retry is executed). Allowed values for this option are in the range between 1 and 10 retries. For values above the maximum limit, the maximum allowed value is stored.
Number of ping retries option
