Via E3 |
E3 Viewer can be executed using the Default toolbar, using the following options:
•Saves and runs the Domain : Saves all project configurations, executes a Domain, and then executes an E3 Viewer
•Runs/Stops Domain : Executes or stops Domain execution
•Runs/Stops E3 Viewer : Executes an E3 Viewer, or stops its execution in case it is already open
When an E3 Viewer is executed, the window on the next figure is displayed, indicating a connection status.
E3 Viewer connection status
Whenever loosing a server connection, E3 then tries to reconnect automatically, according to server's configurations. To determine which server performs a connection in case of an E3 Viewer failure, it is necessary to configure the Servers option, configured via E3 Admin, as explained in chapter Domains.
