Executing WebViewer |
During WebViewer installation, e3web.asp, e3web2.asp, docwrite.asp, docwrite2.asp, and e3downloader.cab files become available for user configuration. These files are located on the same directory where E3 was installed, on the web folder.
•e3web.asp and docwrite.asp: Responsible for loading and starting E3Downloader ActiveX
•e3downloader.cab: ActiveX sent to a client machine and executes the installation of e3webviewer-x86-enu.exe
•e3web2.asp and docwrite2.asp: Responsible for loading and starting WebViewer's ActiveX displaying the application executed on client machine's Internet Explorer
The docwrite2.asp page is initially configured as if E3 Server and web server are executing on the same computer. However, users can change this page's source code to meet their needs. To do so, change the following line on docwrite2.asp file:
var Domain = getDomain();
To the following code:
var Domain = "IIS server's external IP";
If users want to inform a valid initial Screen, different from the one configured in the Domain, they must change the Screen parameter on docwrite2.asp file, typing in the Screen_Name value a valid application's Screen name. Example:
<param name="Screen" value="Screen_Name">
If users want to inform whether a ping command to a server must occur before trying a connection, they must change the Ping parameter on docwrite2.asp file. Its value can be either "True" or "False". Example:
<param name="Ping" value="True">
If this line is omitted, a ping command is executed.
If users want to specify a different directory to save E3 Viewer's cache, they must change the CachePath parameter on docwrite2.asp file. If it is omitted, then Windows' default temporary directory (the TEMP environment variable) is used. Example:
<param name="CachePath" value="Cache_Directory">
If users want WebViewer to search for other servers on a network if it cannot connect to a server specified on the Domain parameter, they must change the UseServers parameter on docwrite2.asp file. If this parameter is not informed, WebViewer tries to connect only to the server specified by the Domain parameter, which is its standard behavior (a "True" value). Changing this value to "False" only works for servers and WebViewers on the same network. Example:
<param name="UseServers" value="False">
WebViewer's configuration to open in Read-Only mode is performed via StartReadOnly parameter, with values "True" or "False", on docwrite2.asp file. If there is no such item, then it assumes a "False" value (this behavior is compatible with previous versions). Example:
<param name="StartReadOnly" value="False">
In both cases, this configuration is only effective when opening WebViewer. If this parameter is changed at run time, WebViewer's connection or reconnection is not affected at all.
If users want to navigate to a page other than the default after loading WebViewer, they must change the value attribute of the URLToLoad parameter on docwrite.asp file to a new address. Example:
<param name="URLToLoad" value="URL">
If this line is omitted, e3web2.asp page is then loaded.
If users want to specify whether WebViewer installer must or must not install ActiveX Control Pad (MS Forms), they must change the InstallACP parameter on docwrite.asp file with values "True" or "False", respectively. If there is no such item, it assumes a "True" value (ActiveX Control Pad is installed). Example:
<param name="InstallACP" value="True">
NOTE |
If the InstallACP parameter is configured to "False", application Screens using MS Forms may display errors during their loading process, if MS Forms objects were not previously installed by another application, such as Microsoft Office. |
Both servers and WebViewer can execute on the same machine or on different machines. The next topics show how these situations apply.
