Communication Errors Tab |
On an E3 Viewer, users can view Tag communication errors when they are linked to Displays or Setpoints. This is possible by configuring information on the Communication errors tab, available on Viewer properties.
The available options for this tab are described on the next table.
Available options for Communication errors tab
Option |
Description |
View communication errors |
Enables or disables the visualization of communication errors |
Text |
Contains the text to be displayed in the Setpoint, in case of a bad value quality |
Font color |
Contains the color used in Setpoint's text |
Background color |
Color for a Setpoint's background. It is equivalent to change the Setpoint's ForegroundColor property, but this change is not performed effectively, because the value of a Setpoint's property is not changed |
