RAM and Demo Tags |
To export RAM and Demo Tags, follow these procedures:
1.In Elipse SCADA's Organizer, click the Tags item.
2.Click Export.
Exporting RAM and Demo Tags
3.Select a file's location and name to generate. In addition to a file with Tag settings, a new file is generated with the same name followed by an _Alarms suffix. This file is used later when importing alarm configurations to E3.
To import these Tags to E3, follow these procedures:
1.Insert a Data Server in Organizer.
2.Rename this Data Server to Data, so that all Screen object Links are correctly imported later.
3.Right-click this Data Server and select the Import option.
4.On the list of file types, select the Elipse SCADA files (*.e2f) option, and then select the file previously exported, without the _Alarms suffix. There is no need to select a template.
