Alarm Configuration |
An Alarm Configuration is exported automatically when exporting Tags, by following the previously described steps. In addition to the file with Tags, a file is generated with the same name followed by an _Alarms suffix. For example, if the selected name is "InternalTags", then the generated files are InternalTags.e2f and InternalTags_Alarms.e2f. This second file with the _Alarms suffix contains the alarm Configuration of all exported Tags. To import these alarms to E3, follow these procedures:
1.In Organizer, insert a new Alarm Configuration, and insert an Area.
2.Right-click this Area and select the Import option.
3.If this import process was successful, alarms must appear without any warnings. If the corresponding Tags were already imported, all references must appear in blue.
