Connect To |
The Connect To option is used to determine an E3 Studio connection to a server. This option allows configuring in which Domain server an E3 Studio must connect, and also allows specifying whether an E3 Studio must retrieve a license from the server where the Domain executes or if it must retrieve that license from another server. To use this resource, click the File - Connect To menu to open the dialog box on the next figure.
Connect To window
Available options for Connect To window
Option |
Description |
Connect to local server |
Enables a connection to a local server |
Connect to a server in the network |
Enables a connection to a network server. To do so, select it on the combo box |
Get license from the current Domain server |
Uses a license from a server executing a Domain |
Use license from the following server |
Uses a license from another server, not the one executing the current Domain |
If a connection to either server (Domain or license) is down, E3 Studio is then disconnected from the other server. Its last configuration is stored on Windows Registry, and the next time E3 Studio opens, it connects to both Domain and license servers used for the last time.
If a license server is not available or there are no licenses left, then E3 Studio works in Demo mode. An E3 Studio without a license (Demo mode) can only connect to an E3 Server also executing in Demo mode.
If a license server is other than a Domain server, the name of this license server is displayed in the title of E3 Studio's window, License on local server or License on <Server_Name>.
If a license server is specified, E3 Server's license window on Domain server identifies the name of a server borrowing a license for E3 Studio, SERVER1 (License borrowed from SERVER2). In this case a license listed on the Domain server is not part of the total number of E3 Studio licenses in use on that server.
If a Domain server does not have a license, and an E3 Studio connects to this server by using another server's license, then this Domain server temporarily switches from Demo to E3 Studio mode, switching back to Demo mode as soon as this E3 Studio session closes.
NOTE |
When E3 Studio is using a license borrowed from another server, it must remain open while this application is executing. If it is closed while this application is executing, the borrowed E3 Studio license, which allows executing an application for up to six hours, is released, and E3 Server ends application execution in no more than 10 seconds. |
TIP |
When users connect to a server, it is important that applications be opened using a network path. Instead of using c:\projects\project.dom, use \\server\projects\project.dom. This way, an E3 Studio and a remote E3 Server can access these files using the same path. |
