E3SampledData |
This is equivalent to the SampledData function. Its formal description is the following:
E3SampledData(
@strTable VARCHAR(100),
@iModMin int,
@dStartDate float,
@dEndDate float,
@strWhere VARCHAR(4000),
@type int,
@bQuality int)
Where:
•@strTable: Name of a table to query
•@iModMin: Interval in seconds to interpolate each value within this interval
•@dStartDate: An initial date, in Float format
•@dEndDate: An ending date, in Float format
•@strWhere: Filter options for the value
•@type: Data type. Possible values are 0: String, 1: Bit or Integer, or 2: Analog
•@bQuality: If different from 0 (zero), only includes Tags with Good quality
This Stored Procedure returns its results with E3TimeStamp and FieldValue columns.
