E3RawData |
Returns values from a table without aggregations. Its formal description is the following:
E3RawData(
@strTable NVARCHAR(100),
@dStartDate float,
@dEndDate float,
@strFilter NVARCHAR(4000),
@strOrder NVARCHAR(100))
Where:
•@strTable: Name of a table to query
•@dStartDate: An initial date, in Float format
•@dEndDate: An ending date, in Float format
•@strFilter: Filter options for the value
•@strOrder: Options to order results by a field different from E3TimeStamp
This Stored Procedure returns its results with E3TimeStamp, Quality, and FieldValue columns.
NOTE |
This Stored Procedure is not available as an option in the Functions item on the Fields tab of the Query associated to the Storage. |
