E3ArchiveInterpolate
Returns points immediately before and after an instant, as exposed in the ArchivedValue function, but only for the Interpolated subtype. Its formal description is the following:
E3ArchiveInterpolate(
  @strTableName VARCHAR(100),
  @dDate        float,
  @strFilter    VARCHAR(500),
  @type         int,
  @bQuality     int)
Where:
@strTableName: Name of a table to query
@dDate: Instant in time for the search, in Float format
@strFilter: Filter options for the value
@type: Data type. Possible values are 0: String, 1: Bit or Integer, or 2: Analog
@bQuality: If different from 0 (zero), only includes Tags with Good quality
This Stored Procedure returns a single result row with E3TimeStamp and FieldValue columns.
