Rectangle
Rectangle
Allows drawing rectangles, created from two vertexes. To use this object, follow these procedures:
1.Select the Rectangle Rectangle option on the toolbar of a Screen.
2.Click the Screen to create the Rectangle's origin vertex then drag the mouse diagonally to its final vertex, until the object reaches the desired size and position.
