Display
Display
Allows creating an object that displays Tag values at run time. To use this object, follow these procedures:
1.Select the Display Display option on the toolbar of a Screen.
2.Click the Screen to create the object's origin vertex then drag the mouse diagonally to its final vertex.
3.Right-click the object to open its Properties Window. On the Item tab, select the Tag to link to the Display's Value property.
