Rotate |
Allows rotating a Screen object having as origin its center or at any other point on the Screen. To use this resource, follow these procedures:
1.Select an object on Screen and click Rotate on the toolbar of a Screen.
2.Click one of its rotating vertexes, in green, and drag the object to the desired position.
3.If needed, change the object's rotation center, indicated by a green circle.
NOTE |
•For Picture-type Screen objects using the Bitmap file format (files with a .bmp extension), the rotate feature is not available. •In case of changing the rotation center of a Screen object, its contextual menu starts displaying the Reset Rotation Center option, which allows undoing that change and returning the object's rotation center to its default. |
