Pan
Pan
Allows moving the content of a Screen with scroll bars in E3 Studio or in E3 Viewer, at run time. To use this feature in E3 Studio, follow these procedures:
1.Select the Pan Pan option on the toolbar of a Screen.
2.Click the Screen to drag it. The mouse pointer changes to the icon Screen selected.
To use this feature in E3 Viewer, follow this procedure:
1.Right-click E3 Viewer and select the Pan option on the contextual menu.
NOTES
In E3 Studio, as well as in E3 Viewer, the Pan option is always available when using the middle mouse button.
In E3 Viewer, that is, at run time, clicking Screen objects such as Buttons, Displays, and SetPoints, among others, prevents using the Pan option, because Screen objects capture the mouse pointer's behavior. In these cases, users must use the options available for the Pan option (middle mouse button or contextual menu) only on Screen's area.
