Group or Ungroup
Group or Ungroup
Allows grouping more than one object into a single one, with specific properties. To use this feature, follow these procedures:
1.Select on Screen the objects that are going to be part of the group.
2.Click Group Group to create a new object. This operation can be performed in cascade, and a group can contain any objects, including other groups.
3.To undo this action, click Ungroup Ungroup.
4.To edit an object contained in a group, right-click the object and then select the Edit Group option.
NOTES
Users can adjust objects inside a group to the nearest pixel, which is known as a Snap to Pixel effect, by using the shortcut key CTRL + Spacebar. In this case, that effect is applied to every object inside the group, and it can be undone by using the shortcut key CTRL + Z.
To leave the edition mode of a group of Screen objects, double-click the Screen's area outside the group.
