Fit
Fit
The Fit Fit option allows toggling between two commands. The first command resizes the Screen to fit in the visible area and the second command restores the previous zoom level and scroll bar position.
NOTE
This toggling is lost in the following cases:
When moving a Screen's scroll bar
When changing a Screen's zoom mode
When changing a Screen's alignment mode at run time
When changing a Screen's useful visible area
To keep the fitting of a Screen to the visible area, use the Full Screen Full Screen option on the Zoom menu.
