Generating an Export Menu |
To use this feature, write the following script.
Sub Rectangle3_Click()
Set report = Application.LoadReport("[Report3]")
Select Case _
Application.SelectMenu("PDF|Excel|HTML|RTF|Text|_
TIFF|Text(CSV)")
Case 1
Report.Export "PDF", "c:\mail\reports\report.pdf"
MsgBox "Exported to PDF!"
Case 2
Report.Export "EXCEL", "c:\mail\reports\report.xls"
MsgBox "Exported to XLS!"
Case 3
Report.Export "HTML", "c:\mail\reports\report.html"
MsgBox "Exported to HTML!"
Case 4
Report.Export "RTF", "c:\mail\reports\report.rtf"
MsgBox "Exported to RTF!"
Case 5
Report.Export "TEXT", "c:\mail\reports\report.txt"
MsgBox "Exported to Text (CSV)!"
Case 6
Report.Export "TIFF", "c:\mail\reports\report.tiff"
MsgBox "Exported to TIFF!"
Case 7
Set reportFilter = report.GetExportFilter("TEXT")
reportFilter.FileName="c:\mail\reports\_
report2.txt"
reportFilter.TextDelimiter = ","
report.Export reportFilter
MsgBox "Exported to TXT using a filter!"
End Select
