How to Create Reports Printing Only Value Average at Every Five Minutes
To do so, users must create a new group in the Report. This group has a Header and a Footer Section. The general layout is the following:
PageHeader: Contains column titles
GroupHeader: Remains empty, but its DataField property is equal to "CLng(E3TimeStamp*288)", because the E3TimeStamp field is the date and time of data in Gregorian format, days since 1/1/1900, where its integer part is the number of days and its fractional part is the hours and minutes. Multiplying by 288 corresponds to a total of five minutes since 1/1/1900. The CLng function converts a 32-bit integer and deletes its fractional part, so that intermediate minutes and seconds do not display. This group is then printed each time this number changes, that is, every five minutes. Check the NewColumn and NewPage properties, which must be set to 0: ddNPNone
Detail: Contains SetPoints for table fields. Its Visible property must be set to False, so that each data acquisition that composes a five-minutes average is calculated, although not printed
GroupFooter: Contains the following fields, representing SetPoint's average:
DataField: Names of table fields, such as in Detail Section
SummaryFunc: 1 - ddSFAvg
SummaryRunning: 1 - ddSRGroup
SummaryType: 1 - ddSGrandTotal
The only exception is for the Date/Time field, which is a standard SetPoint with its DataField property set to "=CLng(E3TimeStamp*288)/288".
ReportFooter: Blank or any other value
If this query is between 00:00 of one day and another one, its result is composed by 288 printed rows with an average of fields at every five minutes.
