Query Setup
Query Setup
To extract data from a Database, users must configure a Report's query. There may be many different queries for the same Report, but only one can be active at a specific moment. To do so, follow these procedures:
1.Configure the DataSource property with the name of a Database where this query is executed. In this case, "DBServer".
2.Specify the Table property with a query table, which in this case is "Data".
3.Configure the Name property to keep its original name, that is, "Query1".
