Usage Example |
The following example shows the daily average of a query field in the Report. To do so, follow these procedures:
1.Insert a new GroupHeader/Footer in the Report.
2.Configure the GroupHeader's DataField property to "=Day(E3TimeStamp)". This specifies that the average calculation is performed on a daily basis.
3.Insert a SetPoint in the GroupHeader with the DataField property equal to "=Day(E3TimeStamp)".
4.Insert a SetPoint in the GroupFooter with the DataField property equal to the field name where the average is calculated.
5.Configure the following GroupHeader's SetPoint properties:
•SummaryFunc: 1 - ddSFAvg
•SummaryGroup: GroupHeader1
•SummaryRunning: 1 - ddSRGroup
•SummaryType: 3 - ddSMSubTotal
