Round Rectangle |
A Round Rectangle object is a rectangle created from two vertexes, with round corners based on a rounding factor.
When inserted or edited, it displays a small point next to its upper left corner, which allows modifying its rounding factor.
Round Rectangle
After inserted on a Report, this object is named as "Shape".
