E3Chart
E3Chart
An E3Chart object is an ActiveX component used to show a chart displaying Tags varying in real time, and also to show historical data stored on a Database.
E3Chart
E3Chart
NOTE
An E3Chart cannot be added to a Report's Detail Section.
There are some functional differences between an E3Chart in an application and on a Report. In an application, an E3Chart is capable of displaying charts with either real time, historical, or mixed data. On a Report, on the other hand, an E3Chart is not capable of using real time or mixed data, only historical data.
Notice that no Report object can be externally accessed, that is, when users create a Report via application, its properties and its object's properties are not accessible via application scripts. To do so, changes in these objects, including E3Chart, can only be performed directly in E3 Studio, or in Report's own scripts.
For more information on this object, please check the E3Chart chapter.
