Simple |
In a Simple Link, the value in the Source option is copied to the property each time the first one is modified.
Simple Link
To use this resource, follow these procedures:
1.Select the object for the Link.
2.Right-click this object and select the Properties option.
3.Click the Links tab and select the property to create the Link. E3 Studio indicates several types of Links.
4.In the Source option, select the Link and click to indicate the property to create a reference, or write down an expression in this option.
